Poor fit of Magnaflow exhaust?
Anyone had any issues with their Magnaflow exhaust? I got mine installed the other day and one tailpipe is noticably longer than the other. Am I the only one? I sent an e-mail to Magnaflow and this was one of the questions that was asked of me.
![](/images/staff.gif)
really? thats a new one.. my tailpipes fit perfect nothing noticebly longer.. ill take pix when i get the chance
well i got mine like 3 weeks ago dont know if they were fixed by then or not
It could be the mid pipes are swapped .I think one is longer than the other if my memmory serves me.Not possitive but should check that also.Hope this helps.
What I had to do was loosen up the side that was sticking out more (in my case it was the right side) and pull back on the muffler assembly unit as hard as you can with all your weight behind it. In my case my muffler assembly unit moved back ever so slightly about 1/3 of an inch into the mid pipe and I had to hold it in place (you have to hold it with a ton of force) and tighten that bastard up while keeping it held in completely and then you will be good.
Don't except one tip sticking out more than the other, I did at first and all my friends noticed it and it was only 1/3 of an inch. I actually posted pics in my magnaflow review post, showing the right tip off slightly and then showing it after I fixed it correctly. Good luck, and believe me, it should and will line up exact, you will be happy and proud of the look when it's right, I sure was.
