Jwt Review
#47
Super Moderator w/ Boost
I wish I could see your setup in person Max. But if you could see mine, the mounting bracket on the intake is not twisted enough for me to screw it in securely. I was contemplating running it without the mounting bracket, but I figured loosely screwing it in is better than not having it screwed in at all.
#48
wrathletik1....don't try to bend the twisted bracket from JWT, slightly bend down the tab of the car's bracket that the twisted piece attaches to. It's easy to take off and thats what got my alignment correct and clearance from the power steering fluid.
#51
install: installed mine earlier today.. easy install, passenger side intake rides up higher than the driver side.. i'll look into the fix when i have more time, but it really doesn't bother me
power: i reset the ecu (using the disconnect battery method since the pedal thing is a pain, good to know the HD keeps all stored info and doesnt erase it).. drove like a mad man for a few hours tonight. my butt actually told me it felt a tiny more kick (i'd assume thats torque) mid and high rpm when i first press the gas. high end power in higher gears didnt feel any different. i expected no real gain so this was not disappointing news. note - im used to driving my car alone, today i had 1 or 2 passengers at all times.. so in retrospect, the comparison for this category is not really fair and i wont be able to judge the power til tomorrow morning
sound: this was most important to me when i bought the intake. i was left slightly disappointed mainly because i expected a lot more of a deeper and louder growl. my buddy with a 6spd g37 with injen was with me all day and hands down his sounds better from both inside and outside the car. it was easy to compare the sound when we were revving or riding side by side.
we had quite a bit of fun on the roads but i cant go into the details of the outcome since its not allowed on this forum
overall rating B+
overall rating B+
#52
overall rating B+
overall rating B+
#54
Design is the same for new intakes than for the first batch, too crowd in that area for them to do something else, I understand your frustration with the passenger's side as I have installed 2 and that side is not as easy as the driver's side, but guys, I don't know how else to explain you, it's not easy, but mine and my buddy's, after some 10 minutes playing with the intake moving it side to side and up and down, are in the same level in both sides. Again, they get leveled, you just need to play a little more in that side, keep those screws loose until you find the perfect spot, then tight them.
Look at how my buddy's intake looked when I first installed it:
Look at mine when I first installed it, looks at the front of the filter so you can see clearly:
Look at how it looks now that I trimmed the Air Inlet as per instructions and adjusted it like I mentioned above.
#56
the intakes themselves were quality built for sure. good material and design. the only sign i saw of them being rushed was that there were a bunch of metal shavings hanging off where the air sensor goes in, and one or two small shavings inside the actual filter. had i not looked before the install, this could have seriously damaged my engine.
#57
#58
erasat, my intake looks like the first picture you posted. seems like the one on the passenger side is rubbing up against the heat shield on one side and the bottle on the other. the only way for it to move is to go straight down and although i trimmed half of the inlet that was protruding, that just wasn't enough. this is a picture i took of how the install looks right now. im gonna play with the setup a little more when i have time and will probably fix it. but like i said before, this doesnt really bother me and i cant see it being a problem so the intake is perfectly functional. thanks for all the support erasat.
#59
MaDd, take a close look at the MAF sensor position on your passenger's side, in mine, for it to be better leveled, turn it clockwise, you will see that doing that will make mores space between it and the PS bottle, just loose all screws and the OEM tube's brace, and twist it, push it to the back while doing it so it fits better and avoid contact with the inlet and the Heat shield.
#60
+1 on that .. I had two huge metal splinters hanging down when I put in the sensor.. If I didnt look these would of probably fell off and could of done something bad ! Mine were a inch long
Slapshot1
09-27-2015 08:40 AM
joebrez
09-22-2015 11:54 AM
