CEL for afretmarket cat`s
Hey folks,
Was driving today home from work and my CEl came on i checked the codes and its P0420 and P0430 looked up online and found out its my cat`s. I have my BERK`s cat`s for 2 month now with FI exaust and everything was fine till today. I had same problem when i just installed them and i had to reset codes 3 times then it was fine for 2 month and now again. Is that normal or something is wrong?
I am having same problem as you with FI HFC.
It was happened two times after i changed back on may.
It's looks like after hard run it happened to mine.
how about yours?
btw how do you get that codes ?
how about yours?
im in the same boat as you guys.....i got FI hfcs and the SES light came on 2 weeks ago....code reads that its the cats....
also i hear this ringing sound every so often..when I pass 3400 rpm...its a very faint rapid ringing sound...like a coin shaking in a steel glass really fast....
i reset mine, but it only lasted 1 day before it came back on...so imma put my factory cats back on tomorrow so I can see whats going on in there....will let u guys know
Fast Intentions,
any ideas on whats going on?
Fast Intentions,
Location: Where the kids are high and the grades are low. NYC
02 sensors were broken during the install, common problem. (bolts on our cats or anywhere for that matter have no antisieze and often break while power tools drill the shyt of out them- all the vibration from power tools- broken sensors)Couple of guys have had this problem on here.
Ive had my HFCs installed for 4.5 months...i dont think it would take that long for the O2 sensors to finally act up....
I did get it checked out by the dealers, and they said the sensors were fine...so not sure...
i have FI HFC with my previous mod stillen long tube intake/cat back exhaust for about a month and never had SES light on.
even with passing 6K rpm street racing. Hmmm.. I wonder ... if i add
JWT popcharge will it trigger SES light to come on???
Last edited by bluenet123; 08-09-2008 at 03:06 AM. Reason: Hmm... 8 bottles of corona...
i dunno, but I had it for 4.5 months-ish before the light turned on, and the only other mod i have is the FI Intimidator exhaust
hmm.. do you race alot?
I had stillen intake/cat back for about 3~4 month now and
I never had any issue from day 1 even after FI HFC installed.
I hope I don't have any SES light issue....
bluenet123, there is a chance you will get the SES light. I have gotten it once and I have Berk HFCs and JWT intake. I am rather confident it is due to a spike in the AF ratio at times. My AF ratio was at 11 stock but now I am running at mid 13s. Have not seen it again yet but we will see.
No i dont race alot.....ive only hit 6.5k rpm maybe 2ice or 3 times since ive had the setup
I had my FI HFC installed 2 months ago and my came on last week. I reset my ecu to clear the code tho. I also noticed when cruising @ 80mph/3200~rpm the HFC vibrates when i'm on the throttle.
I'm going to go with Bboys thoughts and say its the AF readings...I doubt that its the 02 sensors as I just like yourself had them for 3 plus months before anything showed up...
Question for everyone (bboy)...Any concern about the code being up or do I HAVE to clear it? It's going to be bothersome to constantly do so...Instead I'm training myself to just accept the light for now...Thoughts?
PS. I dont have other issues that some are talking about...Just the SES light...
soo I plan on buying berk HFC's within the next few weeks and the only reason I was going to go with HFC's is because I didnt wanna throw codess but if the HFC's throw em arent I just better off going with test pipes?? cheaper and a little more hp no???
Join the club bud...I've had my berks on for about 3 months...No issues at all...After a hard run the other night the SES light came on...I called the dealership to bring it in but I had to cancel my appt...3 days later the SES was gone...Sure enough last night I had a real hard run and up popped the SES light...
I disagree with this just because I have never thrown a code until I had the JWT installed which increased the AF number even more. I have had only one code thrown so far. It is not on all the time so it just seems to be hit and miss. I would recommend getting a AF measurement if you are worried. Stock I was at 11 average. After the HFCs I was just under 13 if I remember right. If you are 12 or more stock then HFCs might give you a light when driving hard. With test pipes, keep in mind that they are illegal everywhere and are easy to tell if a car has them, you will have a gas smell when stopped at lights, the SES light is always on, and they are raspy which I hate. Make sure you factor that into your decision.
