Berk HFC install by dealer problems
Test Pipes
I would like to go with test pipes also. But someone said on here that with TP's you'll smell raw gas at traffic lights. Anyone else experiance that? Maybe reflashing the ECU corrects that???? Anybody know???
DIY Headers
Thanks for the info AZ. I have a fully equipped shop with a lift. I might consider doing it myself. I've done a lot of overhauls and engine replacements on older technology, but its been a while. I'll have to take a look at it. Sure its not a bowl of candy.
I will have Berk HFC install by this tuesday. Just wondering any ploblem after install at all like warning light and warning sensor. and do i need to reset ECU by unplug the battery.
Also with yearly inspection...I have confirmed with Berk Tech they mention to me that will be ok.Is that tru? Thx for your advice.
I live in NYC btw
Hi! AZ
I live in NYC btw
I live in NYC btw
Unless the installer screws something up, you will have no issues at all; just the sound of pure sex coming out your tail pipes. One thing I would suggest to the installer is to keep the plastic on until he is all done. This will keep his finger prints off the SS so when it burns in it will not show the discoloration.
You can do an ECU reset or just go out and drive the snot out of it, it will learn.
The only state where these are an issue is CA, so being in NY, you are fine.
I got Berks and I love them!!! Best HP for the buck so far and they sound really good with stock muffler.
THX! for clearify my curious! Now i'm happy to know.
Ya, the O2 sensors that are in the CATs should be removed so they don't accidentally break them. A few people have had theirs broken while installing the HFCs and had to pay a couple hundred for each one to replace them.
Not just the cats, the O2 sensors in the headers are the VERY fragile ones. You need to remove all O2 sensors, especially when breaking the top bolts near the headers. I personally had issues with the SES light coming on, and my installer didn't fudge a thing. It was just do to the increased flow not matching the registered A/F ratio settings the car learned while stock. A simple reset of the A/F ratio learned values will eliminate the SES light though. Good luck
#29
Thanks to you all with alot of help.I just read Installation guide from
Stillen HFC.It's ploblably similar to BERK installation.Will see and i will let yall know result after i'm done installed.BTW i'm leaving for camping by 4th of July
with this HFC hopefully no ploblems on the 1.5 hour drive.
