BERK HFC's Installed
Old 02-18-2008, 02:51 PM
peterbanks
peterbanks's Avatar
First, Very Happy with the outcome. Second, don't even think of doing this at home unless you have some serious tools, and a friend to help. Seriously, the install took about 1 hour and 45 minutes, but an hour of that was spent removing the bolts on the oem cats that you have to access from the top of the car. My car only has 1900 miles and those bad boys were not giving it up. Once they were off everything else went smooth. You do have to remove the intake boxes to get to the top bolts. Anyway, like I said before VERY HAPPY with the outcome. If any of you are in Naples, I highly recommend Summit Automotive. They did a excellent job.
Video of sound before and after:
VIDEO
Video Under Load:
BERK HFC's Under Load
Video in car with windows up and sunroof open in the vent position:
BERK HFC's In Car Sound
Couple pics:
More Photos: GALLERY
Enjoy.
Old 02-18-2008, 03:08 PM
GiGGaplease
GiGGaplease's Avatar
whoa, nice! you can actually heard the growl even louder. good mod.
Old 02-18-2008, 03:14 PM
Dieseldoug22
Dieseldoug22's Avatar
So are you throwing a check engine light or anything? And does the performance seem any better?
Old 02-18-2008, 03:16 PM
gan78mao
gan78mao's Avatar
so how much are the HFCs?
Old 02-18-2008, 03:19 PM
GiGGaplease
around 600 for one.
Old 02-18-2008, 03:20 PM
gan78mao
gan78mao's Avatar
Originally Posted by GiGGaplease
around 600 for one.
oh dang tats bank!! i rather spend 1/10 of the money and get my resonators removed!! haha j/p!=P
Old 02-18-2008, 03:27 PM
solopresident
solopresident's Avatar
nice! i agree no instlling at home unless you know what you are doing. Its some serious work and needs some serious tools. Also, any dyno #'s of it b4 or after?
waas this done for power or just sound? b/c if you want true power a full cat back will be needed to really free up the air flow.
Sounded good.
Old 02-18-2008, 03:29 PM
G37RacerX
G37RacerX's Avatar
Nice, it sounds like a different animal.
for posting pics & videos from the start, take note other posters.
Old 02-18-2008, 04:03 PM
Wicked_limitz
Wicked_limitz's Avatar
what a difference! post some drive by vids whenever you have time.
Old 02-18-2008, 04:07 PM
peterbanks
peterbanks's Avatar
Nope, and you shouldn't get one with the HFC's
Actually only 490 shipped from BERK
Not on my car, but they have been dynoed and the results where 9 HP and 10 TQ
Product Page: BERK
Old 02-18-2008, 04:10 PM
peterbanks
peterbanks's Avatar
More info taken from BERK's post on MY350Z:
Berk Technology Metallic Substrate High Flow Cats (HFC’s) – Spun Catalytic Converters for the 2007 350Z, G37 (VQ35HR).
These are METALLIC substrate cats, NOT ceramic brick cores. They have a much more free flowing cell pattern vs. the ceramic cats you usually see. The catalyst material will not break apart, crumble, powder, lossen, etc. These cats on a flow bench will show nearly the same flow rates as an actual test pipe. These metallic cats have been tested these to over 500 wheel HP on a twin turbo G35. I’m sure you’ll have no problems with YOUR forced induction or N/A Z33.
These cats are 49 state legal, and can still pass strict California SMOG emissions tests (sniffer test). Depending on what state you are in, the cats are backed by Magnaflow’s factory warranty. Warranty varies by location, see the Magnaflow website for your particular warranty terms.
These will include our custom made 99.99% pure copper gaskets. These gaskets have a melting point of 1980 deg F. Unless something is very wrong with your tune, these gaskets are essentially “un-blowable”.
• Magnaflow Spun Body Metallic Substrate Catalytic Converters
• Secondary Wide band O2 Sensor ports included for left bank and right bank cylinders. Wideband plugs included if ports are not in use.
• 100% bolt on. NO cutting, splicing, hacking, etc.
• Gusseted 304 SS support brackets.
• SUS304 Stainless Steel Tubing & Flanges. Many brands brands that use mild steel flanges or 409 SS for the flanges.
• True 60mm piping (2.36") tubing. We use the same size metric tubing as the OEM collector. Most other brands that will use 57.15mm (2.25”) piping.
• Perfect fitment guarantee.
• TIG Welded with silicon bronze at the flange joints rod for ultimate fatigue resistance, (308 stainless at the cat joints).
• Includes all mounting hardware, copper gaskets, mounting bolts, etc..
• MADE IN THE USA.
2007 350Z, G37 VQ35HR Metallic Substrate High Flow Cats (HFC's)
Old 02-18-2008, 04:26 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
Wow it is awesome!!!
Berk is a well proven brand and I loved there products on my maxima.. .
Man I cant wait to get these...
SO you have to get those bolts from the top ???
Old 02-18-2008, 04:33 PM
GiGGaplease
whoa, thats not bad, i was thinking about the fi hfc. whopss.
also, can i get the resonator remove and add a hfc at the same time?
Old 02-18-2008, 04:49 PM
MaxToTheG37
yes thats easy... a shop will do whatever you want ...
Old 02-18-2008, 06:07 PM
MaxToTheG37
Peter... how bout getting some vids with someone taping you go thru the gears and drive bys... I wanna hear this bad...
Quick Reply: BERK HFC's Installed
