Have A Problem Need Help Stillen Intake
Old 02-10-2008 | 05:45 PM
VRG37S's Avatar
VRG37S
Hey Guys I just installed my stillen long tube intake today. I did everything to instructions. I disconnected my battery and hooked it back up when I was finished. Now my PROBLEM my windows won't roll up. As soon as I open my doors the windows go down and won't come up till I shut the door.. Then if you roll them up and open the door they go back down again. HELP ME PLEASE.
Old 02-10-2008 | 05:50 PM
]\[ /-\ ]\/['s Avatar
https://www.myg37.com/forums/tsb-technical-bulletins/174383-door-window-operation.html
Old 02-10-2008 | 05:54 PM
Dieseldoug22's Avatar
Dieseldoug22
Thats an easy fix. You just have to re-initialize the car. Just hope in the car and close door, and turn the ignition to on, you don't need to start the engine. Pull the AUTO-UP switch and continue to pull it up for at least 3 seconds after the window has rolled all the way up. I think once you do the driver side the passenger side should be fine also. If not do the same.
Old 02-10-2008 | 07:02 PM
solopresident's Avatar
solopresident
what you need to do is return the stillen and wait for injen. then the problem will magically disappear. unless you follow the others suggestions. its a feature infiniti put in so you don't lock your keys in the car with the battery dead or something.
Old 02-10-2008 | 07:48 PM
GiGGaplease's Avatar
GiGGaplease
you probably press the button for it not to go up. i did that and thought my car was wrack..
Old 02-10-2008 | 07:53 PM
i'm pretty sure he didn't do that
Old 02-10-2008 | 08:00 PM
LAZY TURBO's Avatar
LAZY TURBO
any news on that intake coming out??
Old 02-10-2008 | 09:37 PM
VRG37S's Avatar
VRG37S
Thanks a lot DieselDoug22 and the guy before him. The procedure worked first time. I was worried there for a moment now I know for the future. The stillen Intake is freaking awesome. Everything bolted right on real smooth. The urethane boxes they made completely block out the heat from the motor. It's quiet under crusing. But when you have it above 3,000 R.P.M'S it has a distintive sound. Way different then the fujita intake. Very deep sound. Really aggresive. Bottom line is Stillen made a great product and will do lots more business with them in the future. Thanks again Dieseldoug22 for your help.
Old 02-10-2008 | 11:26 PM
808MIKE's Avatar
808MIKE
HAHA Congrats Jake on the Intake.! I just Installed the Long Tubes also. And it became a little louder and Deeper now, than with the Short Tubes. And Now has the Looks to go with it!
Old 02-11-2008 | 12:55 AM
VRG37S's Avatar
VRG37S
Yeah now that my car has an intake and exhaust setup on it. The powerband is smoothed out and suprisingly those little upgrades really opened up the motor. I feel I got a little more low end from the exhaust and a little more top end from the intake setup. How do you like you intake. I'm stoked about mine. The quality of the products really makes it worth the extra money. Rather than going with the fujita brand intake.
luisalan
09-06-2015 05:45 PM
ZachThomas
09-03-2015 01:40 PM
RobertoG37s
08-16-2015 06:26 PM
Quick Reply: Have A Problem Need Help Stillen Intake
