Help My g37 push to start sometimes doesn't crank
hi guys my 2011 g37x sedan does like to crank
when ever i hop in the car i have the key and push the button but it go to acc or on but doesnt crank so i do that a few times and after a few tries it just cranks like normal but it soo weird because me and my friends think the button is bad can someone help me with this
Your push-to-start issue could be related to the start button or the brake switch. Make sure you're pressing the brake pedal all the way down when you try to start the car. Also, check the battery in your key fob, as a weak battery can sometimes cause issues.
To see if your key fob battery is getting weak, try inserting the fob in the dashboard slot when starting the car, instead of relying on the wireless connection.
As for the brake switch, these can fail intermittently, just like clutch pedal position switch. Fortunately it's an inexpensive part and a relatively easy DIY replacement.
I agree, check that brake switch first, that's the simplest answer and the easiest fix. Also the clutch switch if your car is MT. Or for AT there are switches which confirm that the car is either in Park or Neutral. That's a bit harder to diagnose and fix but there are threads about it in here.
csa511
09-04-2013 06:25 PM
