2011 g37x AWD lights on
The other day when my girlfriend was driving the awd, traction control, and abs lights came on. I was able to spin one tire going around a corner too so I'm assuming AWD is off. I checked the awd module connection and it's still plugged in, other than the awd being gone everything is working. Any idea what the problem is?
I don't know if there's any codes because I don't have a scanner. I've full throttled around corners from a stop and never had a tire spin before, sometimes the back end will break loose in the rain but that's it. It was dry when it happened though.
Check the 10A fuse. When you take it out that is the lights that will appear on your dash. Make sure the car is off when taking out the fuse, and try another 10A fuse and see if it goes away.
