Help Squeaking noise while turning/going over bumps
2013 G37x sedan
Car is making a noise every time the surface of the road changes, like small bumps, but isn't there on a perfectly smooth road,
the same noise is also present when I turn the wheel left to right...
Any idea what it could be?
I checked the power steering fluid and it looks good, don't have access to a garage at the moment.
Attached below is a video of the squeaking.
Probably your ball joints.. but could be ur tie rods as well
2013 G37x sedan
You may also want to consider replacing your tie rods as a bonus precaution.
That my friend is the date destroying sound of your ball joints failing. They need to be replaced ASAP. It’s not super dangerous to drive with them, but they will ruin your social life… and if they fail you would be able to control your car. So get those puppies fixed.
Might as well
Never done this on this vehicle. So not completely sure if you can replace the joint without replacing the entire arm. But you might as well if you just installed coil overs. Getting some upgraded control arms and tie rods will improve your handling immensely.
I think you are dealing with what the majority of people deal with BC coilovers. After a certain amount of time/miles, they start to squeak and have noise issues. Just put on Google "BC coilover noise forum" and you will see that a lot of people have the issue. I'm not sure what is the fix for it but some have might have solutions that might work. As far as MooseG37 stated it could also be bad ball joints, but you can figure that out by raising the front of the vehicle up and doing the 12 o'clock and 6 o'clock wiggle to feel for any movement as well 3 o'clock and 9 o'clock. Make sure both of the wheels are off the ground when doing it.
Quick update, after washing the undercarriage twice at a touchless car wash, seems like the noise went away?
I live in Michigan so I'm thinking salt or dirt got under some components and caused the noise, I'll check the parts you guys mentioned if it comes back.
Also I forgot to mention I have front upper control arms from SPL, but I don't think that had anything to do with it.
It will probably come back
2013 G37x sedan
G37Cali77
01-09-2019 03:57 AM
