Anyone has any idea what is causing these sounds?
Old 05-12-2021 | 12:57 PM
jesse123456's Avatar
jesse123456
This is enigmatic, been trying to figure that out for a long time. Apparently it is coming from the lower portion of the engine bay , esp from the right side lower portion. You will hear two distinct sounds, the background sound is from the pulley area, but please listen to the 'drrrrrrr" , its intermittent. once a mechanic said it is from within the engine. Please leave your inputs. Thank you
File Type: mp3
File Type: mp3
Old 05-12-2021 | 05:21 PM
Said Amir's Avatar
Said Amir
Does the car sound like a tractor? Maybe the hydraulic lifters?
Old 05-12-2021 | 05:24 PM
jesse123456
it does sound like a tractor , but it comes and goes , god knows where it actually comes from.
Old 05-14-2021 | 09:20 PM
Said Amir's Avatar
Said Amir
Do you have test pipes on the car?
Old 05-14-2021 | 09:26 PM
jesse123456
[QUOTE=Said Amir;4295474]Do you have test pipes on the car ?
No
Old 05-19-2021 | 07:19 PM
Said Amir's Avatar
Said Amir
Then it could be most likely the hydraulic lifters that you are hearing
Old 05-19-2021 | 07:35 PM
jesse123456
How does the repair would go about ? someone said the g doesn't actually have a "hydraulic lifters".. can you enlighten me on this ? Thank you
Old 05-19-2021 | 08:07 PM
Said Amir's Avatar
Said Amir
Yes you are correct it does not have hydraulic lifters but that is what others mention in the forum, or some call it solid lifters.
Old 05-19-2021 | 08:57 PM
ILM-NC G37S's Avatar
ILM-NC G37S
The VQ37VHR does NOT use hydraulic valve lifters. This engine uses solid (aka "mechanical") lifters. The term "hydraulic lifter" is thrown around this forum- and others- casually and VERY incorrectly.
If, and I say IF, the lifters are out of spec, they are replaced. There is NO adjustment.
HOWEVER!, only the EXHAUST side of the valve train can- technically- be serviced. IF any components on the INTAKE side need replacing, the ENTIRE VVEL Ladder assembly has to be replaced.
Hopefully this clears up some confusion.
Old 05-29-2021 | 12:52 PM
mummy2's Avatar
mummy2
That second clip reminds me of my cat that has a broken honeycomb piece inside.
G37xS-Life
06-16-2016 10:53 AM
looslip
11-05-2010 04:32 AM
watermelon626
10-15-2008 09:42 PM
Quick Reply: Anyone has any idea what is causing these sounds?
