I had the same issue last year. It took the dealer three tries to fix it... A screw on hose clamp did the trick. Make sure you clean around the hose connection and top off the radiator.
Thanks x818. I’ll be going to a private mechanic shop and not the dealer. I’ll let him know these details. What did the dealer charge you ?
