Help Gas door motor replacement
Has anyone replaced or removed and cleaned the gas door motor? Mine wont stay shut anymore as of yesterday. There's this little white piston that springs in/out to latch onto the door and keep it in place. Mine is stuck in and if I manually pull it out it just does it again. I tried cleaning it and spraying with some WD-40 but it looks to be broken. Is this serviceable through the trunk or the wheel well?
Kris9884 (04-20-2016)
