Sputtering around 5-7,000 RPM
I looked at mine without removing. They both appeared to be super tight. So, you think I should remove the round intake hose from the rear of the airbox housing and re-install - probably on both sides to be safe?
Super Moderator of Pwnage
Afterwards there was much less "play" in the box with regard to movement as well. Now the revs are as smooth as it should be.
SuicidalG37SGuy
09-10-2015 06:01 AM
