Which brand of OIL FILTER do u use?
#31
for me cost then how long each one lasts say when the oil starts to go dark, and maybe I'll take into account performance wise. Used a pennzoil oil filter once and it was crap swap it out with k&n and the car felt different maybe it was a placebo effect?
#32
The benefit of a larger filter is a matter of debate yet many of us do it anyway. I think the majority of us here that use larger filters believe that more oil can be filtered through a larger filter and possibly better cooling of the oil. The OEM sized filter is also exceptionally small for a 6 cylinder engine compared to OEM filters of a 4 cylinder. The size difference is not that huge from what people have recommended here about 1/3 larger than stock G37 filter.
Does it require more oil yes, about .2-.4 qts more.
#33
Like Telcoman and MitchG37 I use whatever conventional oil is on sale and still a name brand. I usually get a package deal which includes a lower end oil filter which includes Fram, Microgaurd (O'reilly's house brand), STP, and Advance Auto house brand.
Are there superior filters and oils out there? Yes, without a doubt. Given what I subject my car to which is mostly rush hour highway jockying and a redline blast here and there I don't sweat it.
Brian
Brian
#36
Thanks guys for the information. I have been trying to cross reference oil filters that will fit on 4 cars and now I found that I can use the K&N 1010 on all of them. Initially, I was concerned that the reason that Infiniti used the 1008 filter which is much shorter was because of the clearance to the underbody cover. I have the ZSPEED one, which is metal.
#37
I was in Pep Boys today looking to pick up a couple Purolator PureONE filters, when I saw these on the shelf. Looks like a new product designed specifically for synthetic oil. They were priced at $9.99, about $3 more than the PureONE filters. They advertise higher mileage but from what I've seen/read, the PureONE can handle extended OCIs well. Worth the extra coin or just marketing hype? Any thoughts?
Purolator Synthetic Oil Filters
#39
I've used Amsoil Ea filters and oil for 20 years and never had an issue. I've run my oil as long as 19,000 miles with an Amsoil filter. Admittedly, that is about 4k miles over what it's rated for, but I experienced no issues whatsoever.
https://www.amsoil.com/lit/databulletins/g2192.pdf
If you decide to do longer drain intervals, please check your oil level monthly and top off as necessary. Oil will burn off with longer intervals if it's not topped off and you can be left with two quarts of oil which is not enough. Just the nature of the beast, even in a well-maintained engine.
The Ea filters should be replaced every year or 15,000 miles, whichever comes first.
#40
A quarter past stripped
#41
Yes, it is. And no issues as long as the oil and filter are up to the task. With Amsoil, you can change the filter only at 15,000 miles, and top off with another quart of oil and be good for another 15,000. As long as the oil's TBN (total base number) is still high enough, you're good to go. TBN is a measurement of the oil's reserve alkalinity which is used to control the acid byproducts formed through combustion.
I know oil brand choice is a lot like discussing politics and religion but I've stuck with Amsoil because they have the test data to back up their claims and usually spank most of the competition out there (in conditions that are far more severe than I'll ever put my car through).
This is an interesting read on 5W-30 motor oils:
AMSOIL Performance Testing Archives
This is an independent case study on a Mack truck that with 630,000 total miles that went 409,000 miles running Amsoil without an oil change. They tore the engine down and found very light wear.
This guy ran Amsoil in his van for 930,000 miles (doing extended oil change intervals) and upon teardown found the measurements for the engine to be within 1% of the manufacturer's OE specs. The transmission has over 1 million miles on it and has never been overhauled.
This is an interesting look into their gear lubes and how they're tested:
warped ideas (04-21-2014)
Victory
17
10-27-2022 03:45 PM
Victory
09-28-2015 10:49 PM
