Help 2300 rpm max, bucking ???
Oh man do I need help. I have an 09 G37s coupe 6mt with about 55k miles. I was driving on my way to school today when I came to a stop light, wasn't the first of the day or anything. When I started to go in 1st gear I hit about 2300 RPMs and the car started shuddering, bucking, wouldn't exceed the 2300 rmp mark. I let off the gas and it was still running ok. I was probably less than a mile from the dealership so I decided to limp it there, it actually ran / drove fine if I shifted it under the 2300 RPM mark, just took a football field to get it to 40mph lol.
Also... I had noticed for a while that sometimes once I came to a stop in neutral the RMPs would momentarily dip down for a second and then return to normal. I asked the dealer about the hesitation the last few times I got the oil changed and they dismissed it as the probably the fan kicking on. The last Oil change was maybe 3 weeks ago.
Any info on what would make the car buck and shudder once I hit the 2300 rpm mark?? Thanks for any help!!
I dropped it off this afternoon, and seeing it is a Saturday afternoon they probably weren't going to get to it today. So I have zero info from them at this time. Check engine light lit up when the issue started.
Well, dealership said I had no oil pressure in the front of the engine with because of some seals or gaskets that were misshaped or something. I dunno what's the deal, they said its all covered under the drivetrain warranty so that's good. I'm just hoping that there was no permanent damage to the engine.
There's a gasket on your inner timing cover for oil pressure that rips and looses oil pressure.
This happened to mine at 58k and ive seen it happen to many 09 + maximas , muranos etc lol.
Your inner cover will be replaced as its a non serviceable gasket. And its a bitch to replace.
Take a look, the brown gasket is the culprit.
I have a similar problem with my G37s, its a 2011 with about 90K on it (i drive alot of highway for work). Anyway, did the some thing, one night it was fine, the next morning it had a rough idle and would buck, stutter, shift back and forth when accelerating. Dealership says they think its a loose timing gear and the front cover needs to come off. Anyway, they quoted me 3K to fix. This doesn't make me happy. Any suggestions?
Murkr
09-28-2015 10:45 AM
