HELP: Berk HFC install
Okay so i am recieving my Berk Hfcs tomorrow and am looking to install it on my own. Just installed my long tube intake yesterday and everything went fine. I heard the installation is a B**** but i wanna give it a shot. Could anyone give me any tips that may benefit me and make it an easier process?
Thanks
Thanks
lots of PB blaster on the nuts over a couple of days, long 1/2" extensions, and deepwell impact sockets. lots of patience and umph to work on the bolts. you'll need to hit the uppermost bolts through the engine bay and they are the worst (they are called demon bolts for a reason). good luck.
I did a full exhaust install just this past weekend. I posted up a DIY in the tech section. The cats are the longest part of the install, with the right extensions, probably 2 ish hours? The more height you can get to fit under the car, the better. Feel free to PM for more explanation.
8 hours for an exhaust install sounds crazy :-|.. but with the right tools you could have cut the time down to 2 hours. If you can get access to a torch you will be a happy camper. The top nuts require a 2ft long extension with a goosneck adapter and if your nuts are rusted to crap then your best bet is to use some heat. I just installed some new gaskets for a buddy and it took us 1 and 1/2 hours on the ground without a hoist but then again the previous hardware was already replaced with new stuff. Good luck and keep us posted.
Mine took 3 hours, these guys are right, spray PB blaster for days. I did it for a week straight, before I went to work and after, those bolts came right off, and I just used lots if extenstions and hand power. Took 3 hours because I took my time. Spray the mother effin bolts! That's the key
Thanks
Thanks
Alright guys so today i finally put in my Berk HFC's. Sure enough you guys were right. I did it with a friend and it took us 2 hours and 15 min. It was a b**** tho. We snapped 1 bolt on top on each side and had to jigsaw off one bolt underneath. I recommend having your car COMPLETELY cooled, helps A LOT. A lot of cursing coming from underneath the car lol.
UGH I was just doing this today and I don't even wanna say how long it took me and I had to just wrap it all up and call it a night and wait till tomorrow because of one GOD DAMN BOLT on the passenger's side the top left... tried like almost everything and nothing ...and due to trying so much the head of that bolt is stripped and don't know what to do :/ it is a PITA to reach from the engine bay as well as from underneath and best way would be to cut it but I am clueless on how to reach it and how to cut it :/ I have seen a thread on this couple days ago about a stripped head bolt while attempting to install berk HFCs and I can't seem to find it either , any help is greatly appreciated ... my car is just stuck by the house till I get this one bolt out and can put in the second HFC...
Thanks, Mike !
Thanks, Mike !
Damnnn : /, well i would only assume you would have to remove intake and anything in the way if possible, Do you have a jigsaw that you can fit through? Or a power tool that can cut it? I had to cut the bolts with a power tool on mine. Lucky its passenger not drivers side man.
Thanks, Mike !
Thanks, Mike !
from the top or bottom? what power tool did u use ?
