Replace 100% of ATF . . .
for $285 at the dealer a fair price? Supposed to be an Infiniti approved machine that does not flush the system, just R&R all 12 quarts of fluid. At 30K and going to do the rear end again too, did it the first time at 1K. Ref lower engine cover and too old/fat to be climbing under cars.
7AT is completely sealed and has a special procedure to get the fluid out. I thought I read it was a ~$600 bill, so if you are getting $285 for a 7AT it might not be a bad deal.
I dont have a 5AT so I dont know how it works.
Dyi
Think there was a dyi on this. You need a transmission fluid pump which can also be used to remove your power steering fluid. (apparently it helps out alot) and if i rememeber right the 30k service includes new brake fluid and transmission flush for under $400. Might have my price off alittle.
I just had a Tranny Service done for $175.. a little high in my opionion, but the 7spd requires a special fitting to refill and the whole warm up step... from what I could tell about 4+ qts came out
....and that is what worries me or ..should I have more confidence because of it.
I'm changing my ATF for its first change at 110k miles with a very good Infinity deal service shop. They seem to have every confidence it will be fine but I'm worried to do it. If I don't do it it will surely fail anyway and I'm not sure it is wise to run it down. I will have to face the Rebuild possibility I suppose but then people get away with these late flushes to.
Live and learn but at least I paid a fair price.
"c'est la vie", not much your going to do about it now. Better late than never.
Hard to blame the previous owner though. He did bring it in for inspections and regular maintenance. I just wonder if it is a guaranteed fail when I change it. Isnt the machine they use low pressure? I'm referring to all Nissan techs
B Feelgood
09-13-2015 05:56 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
