Floor jack recommendation?
Low Profile Floor Jack - 2 Ton, Rapid Pump® Jack
Is long enough to reach back to the front jack point. There's always coupons and sales. A must if you're lowered, even though you'll still need a 1in thick block of wood to clear the car (again, only if you're riding low on coils).
But keep in mind that this is NOT a race/low profile jack. However, this jack is not aluminum so it's heavy as hell but VERY solid in quality. If you're slammed, then you need some 2x4's or a race ramp to get it on the jack. You know that this is a quality jack b/c you find in many auto shops or tire shops everywhere.
^ This.
Umm...it is low profile. Says so right on the package. It is just like this one. And you are right, it is one heavy beast!
Amazon.com: Arcan 3 1/2-Ton Jack - Red Professional Low Profile Garage Floor Jack XL35R: Automotive
I've got this one - Arcan Quick Lift Professional Service Jack 3 1/2-Ton, Model# XL35 | Floor Jacks| Northern Tool + Equipment
It was the lowest profile with the highest lift I could find. It's heavy, but it works great. It's low enough to fit under my old s2000 and lifted high enough to get my old FJ off the ground even after I installed a lift-kit.
Another vote for the Arcan, i've had mine for nearly 3 years now. Great jack!
Arcan Quick Lift Service Jack
It's low-profile and has a long platform (or whatever you call it) so for non-lowered vehicles it's easy to slide it right to the front jacking point. The low-profile jacks i tested from HF were indeed low-profile, but it rakes towards the end and would end up getting stuck by the front bumper before the jack mount can reach its destination. Thank goodness for HF return policies!
Dropped or not, it reaches the rear pumpkin just fine, too!
I got it for a great price too.
That's the only problem that I've had with the HF one, hence why I suggested a 2X4 or something like that to drive the front wheels on. I've used the HF one for about 6 months now and it's been excellent. It's also heavy as a motha! lol
I got this one for christmas and I love it. I can get it under my car just fine and Im down on coils. Its not aluminum so its heavy but works great. Jack lift range is 2 3/4 in. to 20 in. Jack pad is removable, is 5 1/2 in. diameter, 5/8 in. thick and has a 1 in. receiver pin.
Summit Racing SUM-G1020 - Summit Racing® Low-Profile Hydraulic Floor Jacks - Overview - SummitRacing.com
I need a new floor jack and was ready to buy the Arcan based on above recommendations but found this at Costco:
NOS 2 Ton Aluminum Service Jack by PowerStation
Wondering if anyone has one and if so how well does it perform? 3.5in low lift height up to 19in max height and it only weighs 49lbs.
