Help compressor keeps going on and off
Working on a 2008 g37s compressor keeps coming on and off at random and the air keeps blowing cold then hot mostly hot when ac is set to 60.
Just started happening recently checked the ac system and its holding steady at 55 psi and no leaks were detected under uv light.
Any suggestions on what could be causing this?
My 2009 (had it 3 weeks) does it too. I am sitting at a red light in the HOT TEXAS HEAT! Then, all of a sudden, it starts blowing out hot air.
I have read some posts that it might be the compressor or something liek that, turning off (when ti isn't supposed to). i think it is a known issue. I might talk to dealer about it Friday when I go in for Tranny reprogram and NAV update
