Turning off awd in G37x coupe
#32
Currently running into the same issue. Whether the switch is on or off after rolling for a couple of feet I hear a click and the AWD light comes on the dash signaling the AWD unit is off. Gonna dig deeper and figure this out.
#33
You have a blown fuse same thing I experienced. Also for you to switch modes you have to turn the switch on If am not mistaken to place it in RWD then turn the switch off to engage AWD afterwards turn the car on.
#34
I found another write up and the guy doesn't have any issues with the way he did his but used a different wire, also like you said it looks like the car needs to be off in order to toggle the switch without blowing a fuse (I may look into getting fuses with more amperage too)
#35
Curious why you say this. I've been running RWD with this mod for over a year now on a very aggressive staggered setup. No problems because AWD is toggled off.
Front: 19x10.5 225/35
Rear: 19x12 255/35
I plan on switching to a meaty setup for this season and also getting a new tune / dyno done. Why wouldn't you go RWD dyno if AWD is completely disabled?
#38
With this Mod, does it mean I can run my staggered set up and not ruin my AWD? I just put my wheels on and the awd light flashes. I'm thinking if I do this Mod the car will be constant RWD and I won't have to worry about the tire sizes.
#39
From what I understand, I believe the AWD light on your dash went off because the computer knows that the wheels were changed and it turned the awd system off in order to protect the front diff. You could take the fuse out but I don't think it will do anything that the car isnt doing for you already. Taking out the fuse will make the AWD light go off and then you will be in RWD just as you probably are as of now.
#40
#41
Why buy an awd in the first place if you plan on turning it off? I've run a staggered setup of 20x9 and 20x10.5 on my awd coupe for about 2 years and haven't had any issues at all with my awd system. Many people have done it with no problems.
#42
^^^^^ Kenny - The same reason I put Ti nuts and bolts in my engine bay where I'm the only one who sees them: BECAUSE I LIKE F@CKING AROUND WITH MY G!!! It's a big toy!!!
Sean
Sean
The following 3 users liked this post by VIVID:
VIVID (05-03-2016)
#44
What are your tire sizes??? I currently have 255/35 rear 225/35 front. My variance is way off. Plus my offsets are +20 front and +25 rear.
