Strange noise at start up
#31
Started having the same issue with my G
The belt or pulley noise is extremely loud at cold starts and then eventually goes away when the car gets warmed up - I replaced my serpentine belt about 200 miles ago and the noise just started recently - I know for a fact it's not the belt. The noise seems to be coming from the water pump pulley
Super annoying!!! Strange that it's got quieter after getting a full tank of Gas - Not even sure how the 2 are related but just throwing it out there.. I might have damaged the tensioner pulley while replacing the belt but the noise started after 200-300 miles of belt replacement.
Any one knows what this is? Is this common?
#32
- The belt itself. Highly unlikely bc it’s new but keep in mind this new belt is tighter and shorter than old belt, therefore creating the noise. Move onto the next bullet below.
- Idler pulleys - I don’t recall how many idler pulleys there are, but it could be 2 or 3. These are held on by a single bolt. They have bearings that wear over time and will squeal when cold and worn. A tighter belt will definitely add more noise in this serpentine path. These are cheap and easy to fix (<$20 and a single bolt). Try this replacement first.
- Belt tensioner - 2nd least expensive, easily changed if you chg the idler pulleys. It is right in front of you. 1-2 bolts.
- Power steering pump - more expensive than previous but could be a culprit
- A/C pulley - prob the most expensive fix if this is going bad.
- Crankshaft pulley - highly unlikely but never rule out.
This is the key post for the DIY’r: https://www.myg37.com/forums/d-i-y-i...an-09-g37.html
My guess to why it stopped making noise after filling it up is that the engine sat idle and warmed up the grease/bearings to stop the noise.
You’ll get it but I would start with replacing the idler pulleys and tensioner. <$150 if you DIY
Last edited by petemo94; 01-04-2018 at 08:15 PM. Reason: Fixing formatting that didnt work on the phone
vdpinc01 (01-04-2018)
#34
#36
My car makes a similar sound, I've chalked it up to be the clutch release bearing, as the clutch begins to rotate.
To be noted: I did a power steering flush, and clutch fluid flush and I haven't heard that sound since. These were done approx 2000km ago.
#37
So did anyone ever figure this out?
My car makes the same exact noise that is in the video. Typically only happens after the car has sat over night in the garage. There aren't any other strange noises happening at all other than that one and only for a split second after a cold start. I've attempted to pin point where the noise is coming from by having someone start the car several times while i listened with the hood up. After about 4-5 times of starting and shutting the car off, attempting to find the origin of the noise, it stops making it. This is why i'm having a hard time believing it could be the starter as some have suggested, and makes me question the pulleys. Seems like after a few times of starting, something warms up and the noise goes away.
I was thinking it could be either a idler pulley or maybe one of the pumps/compressors. Any new ideas? or has anyone solved their issue?
cyberone28
09-23-2015 02:56 PM
