2011 fsm?
Old 07-06-2011 | 09:48 AM
voltic's Avatar
voltic
2011 fsm?
Anyone seen a 2011 FSM, specifically section AV?
Old 07-06-2011 | 12:40 PM
rks's Avatar
rks
Is it the same as the 2010?
Old 07-08-2011 | 10:38 AM
voltic's Avatar
voltic
I don't think so, since the 2010 seems to be the same as my 2009 FSM. Should be a fair bit different in the AV section.
Old 07-08-2011 | 04:06 PM
rks's Avatar
rks
I know the 2010 and 2011 Sedans are very close if not identical but I'm not sure about the Coupe. Good luck with your search.
Old 07-08-2011 | 09:19 PM
voltic's Avatar
voltic
Thanks, I'll try that one.
Old 07-13-2011 | 10:31 AM
Fezzik's Avatar
Fezzik
2010 and 2011 are almost identical esp in av. the 2009 and 2010 are different.
Old 07-13-2011 | 09:46 PM
voltic's Avatar
voltic
What's confusing me is I downloaded a 2010 FSM and the AV section looks the same as my car.
Old 07-13-2011 | 11:40 PM
Fezzik's Avatar
Fezzik
Yeah there isnt too much of a change from 09 to 10 but 10 to 11 is very little. I may get the updates for the 2011. It took me forever to get all the FSM in the first place that if there isnt too much a change im not getting it.
Old 07-14-2011 | 08:23 AM
Chris11LE's Avatar
Chris11LE
There is a section or two missing from the 2010 FSM link. I wanted to really dig into it in regards to adding front sonar sensors, and the section that talks about them is missing.
Worst case, hop on infiniti-techinfo.com and get a 1 day subscription (I think its about 20 bux) and you can download whatever is on the site for 24 hours. FSMs, TSBs, owners manuals, etc.
Old 07-14-2011 | 09:58 AM
Fezzik's Avatar
Fezzik
What sections are missing?
Old 07-14-2011 | 08:43 PM
voltic's Avatar
voltic
Seriously I think the AV section is the same from 2009-2010, which it shouldn't be because the video interface is different.
Old 07-15-2011 | 12:41 AM
Fezzik's Avatar
Fezzik
its not the same. if you look closely at the video screen connectors the 09 will show a rgb cable while the 10 will show only a 2 wire digital rgb. little things like that. There isnt much but the screen was a major change.
Old 07-15-2011 | 04:17 AM
voltic's Avatar
voltic
I'm looking at the 2010 FSM and I see RGBS as all separate wires.
Old 07-15-2011 | 08:24 AM
Fezzik's Avatar
Fezzik
ok. look at the 09 AV section pg 375
Now look at the 2010 AV section pg 360
Different wiring
The pg numbers corespond to the coupe.
vamarris
12-09-2018 11:10 AM
SpeedBallDEVIL
10-02-2015 11:20 PM
Soccer4555
09-30-2015 05:31 PM
djdiskino
09-29-2015 07:18 PM
Quick Reply: 2011 fsm?
