Who has the best gas? :)
Old 02-22-2011 | 05:29 PM
  #46
6mtg37s's Avatar
6mtg37s
I usually use mobil, i think it contains ethenol but seems like it lasts longer compared to shell.
Old 02-22-2011 | 06:01 PM
  #47
philter25's Avatar
philter25
Originally Posted by MACS
"What’s more, your local Chevron station may sell gas refined by Shell or Exxon Mobil. Suppliers share pipelines, so they all use the same fuel. And the difference between the most expensive brand-name gas and the lowliest gallon of no-brand fuel? Often just a quart of detergent added to an 8,000-gallon tanker truck."
Excerpt from the article. Perhaps you missed it.
I agree ethanol sucks. It's a scam. Sure, it pollutes a little less, but you have to burn more of it... so it offsets.
No I saw that. My points agree with that. Additive packages are added after a company takes it from the pipeline. All companies get their fuel from the same source, and the difference is additive packages added after that.
The last line in your quote about detergents (aka additives) has a keyword in that line..."often". For most companies, thats the case, but there are a few companies where its not just a quart of detergents.
Its very similar to oils. Most companies get their basestocks from the same place, but the differences are usually their additive packages.
Old 02-22-2011 | 10:34 PM
  #48
BHB 91's Avatar
BHB 91
The best gas is any top brand without the ethanol in it. That stuff is bad for your car and deadly for 2 cycle engines like weedeaters. I lost a blower one time and learned the hard way what that crap will do. It eats away at the fuel lines and inner carb components of the small engines so imagine what it is doing to our G's. Can't be good. The shelf life is only 2 to 3 months as well.
Whoever got this stuff started should be banned to driving Yugo's for the rest of their time!
Old 02-22-2011 | 10:38 PM
  #49
Falcons023's Avatar
Falcons023
I can't find any gas station around me in Atlanta that sells without 10% ethanol. Any specific brand gas that i should check out?
Old 02-22-2011 | 11:40 PM
  #50
BHB 91's Avatar
BHB 91
There are some metro areas that won't sell anything without the ethanol. I used to live in Dallas and you could not find it anywhere without it. I would just try to use major companies like Shell or Exxon/Mobil. The ethanol probably isn't real bad for your car but it is not the best that is for sure. It causes mileage to be worse among other things and it goes stale fast.
I used to have a 67 Chevelle and I did not drive it all that much so I kept a quarter tank in it and used fuel stabilizer to counter act the stuff. It seemed to work OK and I never had carb problems but it was a hassle.
Old 12-27-2014 | 09:20 PM
  #51
Alexander072993's Avatar
Alexander072993
Usually use Mobil, but switched to shell today and noticed a nice increase in mpg... Shell it is then!
Old 12-27-2014 | 10:27 PM
  #52
slartibartfast's Avatar
slartibartfast
I'll bet money the owner's manual for that blower explicitly forbade use of gasoline with ethanol.
Alcohols can eat rubber but automakers have been using o-rings and gaskets that are impervious to alcohol for a couple of decades now. Shelf life is a different issue and you're right, it's not very long.
Old 12-28-2014 | 12:17 AM
  #53
Neddy_G37's Avatar
Neddy_G37
I have been keeping accurate records based on my fuel usage since first buying the car. My results are as follows:
Shell - Good performance, high price, decent mpg
Sunoco - Best performance, average price, lower mpg
Giant - horrific performance, low price, better mpg
Exxon - decent performance, average price, best mpg
I have been running Sunoco Ultra 93 the past 8 tanks and can say the performance has never been better, although my MPG is only 16-17 currently. I rarely drive highway so cant give you any numbers there. It all really depends on what you want, how you drive, and what matters most.
Old 12-28-2014 | 12:20 AM
  #54
Awakence's Avatar
Awakence
Anyone who uses Shell and Chevron know which has better mpg or are they pretty much the same?
Old 12-28-2014 | 11:52 AM
  #55
slartibartfast
You can't compare brands like that without specifying your location. Reformulated gasoline is different enough from gas sold in non-pollution areas that comparison isn't valid enough to create Neddy's matrix. Reformulated gas has lower RVP and generally has ethanol.
Besides, not all brands are nation-wide. No Sunoco stations in Houston, for example.
Old 12-28-2014 | 02:39 PM
  #56
Neddy_G37's Avatar
Neddy_G37
ha, Neddy's matrix. Morpheus and I worked on our fuel charts together.
I am in VA and our gas is reformulated with 10% ethanol.
Old 12-28-2014 | 05:55 PM
  #57
slartibartfast
My apologies to Morpheus.
Old 12-29-2014 | 02:36 AM
  #58
Lamify's Avatar
Lamify
I usually go for 76, Chevron or Shell in no particular order.
Old 12-29-2014 | 09:48 AM
  #59
Djfarhan's Avatar
Djfarhan
i dont give a ****, it is $1.20/gal here :P
Old 12-29-2014 | 01:42 PM
  #60
JT2014's Avatar
JT2014
LOL....
I usually buy whatever is cheapest for 87. But I use shell for 93 because I can use my points for discounts.
