That would be right, but can you even get a jack back there from the front??
I dont remember, as Im now dropped, and had to buy a special jack, and can only jack from the sides.
I bought an aluminum low-profile one from Harbor Freight and was able to use it in the front. It doesn't raise it too much however.
That nipple is the front jack point. The rear jack point is the rear differential. Per the FSM.
i learned mines the hard way. my pinch points on the sides are smashed up pretty bad lol. there was just no other way to slide the jack underneath the car since i got a kit and slammed. oh well, just a car!
I always just place it right on the inside of the pinch welds right up next to it. Then I place my stands right up next to the railing where the pinch weld is. I've done this for the front and rears and never had a problem.
