Battery Changed / Window Goes Down ?!?!?
Old 02-18-2012, 06:35 PM
Coupe Daddy
Coupe Daddy's Avatar
Originally Posted by Mad Nash G
I tried unplugging the battery and with doors closed, no luck. It is like there is a wiring issue. Opening the passenger door should not be causing both windows to drop. At least it did not in my g35. Weird
On a good note, I got my vossens mounted today.
Dang, that sucks. I hope you don't need a new (limit sensor/switch or stepping motor?). I have no idea what is used to stop the windows, just a guess. I would ask the dealership to cover it under warranty, whatever it is. The worse they can say is no.
Congrats on the Vossens! Best wheels for the G, hands down (imo).
Old 02-19-2012, 05:29 PM
Frankyg37s
Frankyg37s's Avatar
did u do the window reset procedure that has to be done everytime the battery resets?
if not thats your problem but i dint read page one so i have no idea if this was mentioned
Old 02-19-2012, 06:25 PM
bythabay
bythabay's Avatar
try 10 seconds instead of 15
Old 02-19-2012, 09:47 PM
Mad Nash G
Mad Nash G's Avatar
That was the ticket. Weird. 15 seconds on the passenger side was too long, but 10 worked like a charm. Cheers!
Old 03-04-2012, 03:15 AM
madlieg37s
madlieg37s's Avatar
Originally Posted by Coupe Daddy
x2 except, not stupid windows, stupid electronics. This is probably in the manual somewhere but I'm too lazy to look, especially since the "press and hold" method worked for me.
On a side note, when I just did mine I discovered that you can only do one window at a time. If you try to do both (at least for me) the driver's side window would not roll back up at all until I opened and closed the door again.
Just went through this earlier today. It is in the manual, although I guess I should have checked the forums first! For future reference, the instructions from the manual are along the lines of:
1. Press the ignition button
2. Roll down the windows more than halfway
3. Roll up the windows completely
4. Hold the window "up" button for 5+ seconds
I was also able to do both windows at the same time.
Raleclair
10-08-2015 02:06 PM
Wreckreation
09-21-2015 06:27 PM
AMCDeac
General Tech Questions
09-19-2015 05:25 AM
SuicidalG37SGuy
09-10-2015 06:01 AM
TVPostSound
09-02-2015 04:09 PM
Quick Reply: Battery Changed / Window Goes Down ?!?!?
