Install Grounding Wires or not on 2011 coupe ?
So I just brought a brand new 2011 G37 coupe and I am thinking about
installing the Betty's Garage Grounding Wires here:
https://www.myg37.com/forums/d-i-y-i...tallation.html
Since, it is supposely going to make the G37 alot more responsive.
However, I heard stories of how it can mess up your car's battery.
Do you guys think it is a good idea to install it on a brand new 2011 G37 coupe ? Or should I wait till the car is more break in and stuff ?
Thanks alot !
Thanks alot !
Guys I can tell you with complete certainty that there aren't any "battery issues" associated with grounding wires. Some people have had battery issues with their cars since they rolled off the lot, it's not connected to my grounding wires and factory grounding issues aren't the cause either, it's unrelated to grounding.
I had the battery problem on my 08 coupe since it was new. I still had the problem after installing grounding my wires. I removed them to be sure that they weren't the problem. The problem persisted. The TSB came out and I had it performed. No more battery problems. I reinstalled my grounding wires. The problem is still gone with the wires.
Grounding wires, mine or others, are NOT causing battery problems. A couple of people may think it is but it isn't. There are hundreds of users who have experienced no issues whatsoever and a couple who have. Their problems aren't grounding wire related.
superjoey
31
03-22-2023 11:56 PM
