Oil change?
Oil change?
So i called up for my 2nd oil change. They quoted me $99 because they said it was the ester oil. My question is how do you know what type of oil they used last time. Because i read somewhere (forgot where) that once you switch from conventional oil to ester oil you can't go back. Don't know if thats true or not.
I asked them why they said that the g37 are recommended to use ester oil. However, reading on here. I have only seen people switching when there engine makes some kind of noise (forgot what the term was). So basically i just want to know because if i can use regular oil it will only be 49 something. If they did switch me to ester oil on my first oil change they never told me they did, which they should have.
So any help from anyone would be awesome
Thanks
Chris
Thanks
Chris
Buy a 5 qt Mobile 1 bottle and a 1 qt Mobile 1 bottle from Wal-mart for $25. A good oil filter from any auto-parts stores for $7. DIY or Pay 10-$15 labor for an oil change.
I would not pay more than $60 for a full synthetic oil change.
Yea thats what im looking at doing. Before my g I had a dodge ram so I changed my own oil on the truck no problem, but then again in the truck i can almost play a game of basketball under it, lol. But on the g there is no way i can get under there unless i use the ramps which im not particularly fond. So i guess i'll take it to my dads mechanic and either buy and bring him the oil or if he carry's a good synthetic at a good price just buy it from him. xixonmn you mentioned buying 6 qts? i though the coupe only carried 5 qts?
Thanks for all the help everyone
Chris
Chris
Is there a place in the front center where it's safe to raise the car? I don't want to collapse anything or bend anything up. There seems to be a center kick plate of sorts where the steering arms hook up - is that a safe place?
Once in the air I would secure if with jack stands on the side of the car for safety.
I've always changed my own oil but getting under the G is hard to do.
Yes there is. I could not get my jack under the car though, not enough clearance. I got some ramps. You can see the circle with a nub in the middle by the front axle.
Prior to lowering the car, i could get my Arcan jack under there without a problem.
After lowering, i needed an inch more clearance so i either drive up on ramps, or jack the side rails a little bit, then slide the Arcan underneath the front-end.
I've got a large floor jack and want to use it to jack up the front end of the G37.
I was convinced by the good reviews about WIX that I read on car repair question. They say that it's the same as NAPA gold and way cheaper. Now, I notice some loud cam chain rattle at start up. Has anyone experienced this? I know that rattle at a second is normal but mine is longer and louder than the usual..
