I'm on their site reading about it now.. is it almost a must for those who want to DIY their oil changes? sounds like it'd make things a whole lot easier. Is it a great product?
use a scissor lift. that is hands down the easiest way. if you can't/don't feel comfortable using a scissor lift, then use a drive on lift and raise the car that way
I actually have the standard (Rhino Ramp 8000) version which works fine, but if I had to do it again I would have spent the extra $12 for the "extreme 12000" version just because of the wide tires.
Is the lift height adequate? it says it only lifts the car 6.5 inches. My car is probably only 2-3 inches off the ground. Is that going to be enough to slide under?
It only cost me $43 for mobil 1 oil change at the dealership... (in canada). Basically the same price as a 5 litre jug anywhere so i just let the dealership change my oil.
I just ordered the Fumoto Valve, when I installed it, does it initially require a crush washer...just want to be sure I pick one up if I need to when I buy the oil and filter.
