Help What is wrong with my car???
So i started the car this morning, everything was fine. I haven't driven it since Sunday. On tuesday i jacked up the left side of the car to put my wheels on and install headlights, then realized i got the wrong lugs so put the stocks back on and lowered the car back down (I don't think this has anything to do with it just added some details)
So as i pull down my road (Car warmed up) i step on the gas and the car starts to like voilently stutter.. No clue why. So i try again, and it get's to about 4k rpm and starts to stutter again. Everything is fine at lower rpm's but it won't even go above 5k.
So i pulled over and tried to rev it above 5k. It got there and just would not pass 5k, so i kept the pedal floored and finally it broke above. Then i revved it a couple more times and it seemed like everything was fine.
Nope, got back on the road and tried going above 4k and stutters again...
Any help would be greatly appreciated.. I would hate to have to take off the exhaust and inatake and head to the dealer...
Its very strange that you arent getting a check engine light.
I would revert back to stock intakes and reset the ECU.
If you are still having problems, take it to the dealer.
As far as the intakes, i have had the injen's on for probably 3k miles or so now without any issues..
I said the same thing that it is weird no CEL is coming on with such an issue.. I would imagine if it were the MAF a CEL would show up almost immedietly..
It doesn't matter if you take the intakes off or not, if there is a problem with the MAF and you've changed intakes they will be able to tell, so there really isn't any reason to go through the trouble of changing it.
I would just leave all your stuff on and take it to the dealership as is.
Terrrrific! Well made an appt for tomorrow morning, crossing my fingers from now until then..
I'll let everyone know what happens, thanks for the advice.
