toped off with 5w20 by accident
So i just did an oil change with penzoil platinum 5w30 but i was missing a bit and so i topped it off to see right after that it was 5w20 i put about 3/4 of a qt.And its 100degres here today im i ok or should i put new oil
For some reason I'm reminded of Richard Pryor's bit about when he set himself on fire freebasing.
Let me tell you what really happened. Usually when I go to bed, I have milk and cookies. One night I had some low-fat milk and some pasteurized, and I mixed them together. And I dipped my cookie and the **** blew up.
As others said, you are fine. If its your first oil change on the car, you should be changing at shorter intervals anyway because you are going to see high trace metals from the break in period. If you change the oil at 3750 miles, you will be fine.
Im assuming that you had 5 full quarts of 5w30 in, and then just 3/4 quart of 5w20? If so, no worries. Change it at 3750.
CiViCKiDD
09-24-2015 10:47 AM
kazama5000
09-22-2015 06:06 AM
