Is the ambient temperature readout adjustable?
Lately I've been noticing I'm 2 degrees Celcius higher than the local radio station - even if I'm in the same location as the station. I'm pretty sure it used to match a few months back. It is always 2 degrees, never 0 or 3.
Is there anyway the sensor could have drifted or be adjusted to increase the offset?
"Official" temperatures are supposed to be shade temps, which might account for the difference. This might also make more of a difference in the summer.
But I'm not discounting the possibility of a problem either. Mine seems to be slightly off sometimes too. I had a loaner car that was about 2-years old or so, and that one was way off, during the winter. I wonder if they need to be (or can be) re-calibrated after a while.
I'm looking through the service manual now. I don't see anything about adjusting it; it looks like there's just a procedure for inspecting the sensor and the signal circuit. to see if it is accurate -- if it isn't, the instructions say to either repair the wiring circuit or just replace the sensor.
If you're still in warranty it might be worth having it checked next time you are in for service.
I recently installed HID fog lights and had to play with the wiring (as mine also function as DRL). I'm not keen on taking this into the dealer until I know a bit more about where the sensor is and how it is wired; they might want to rip out my recent mods.
I think the temperature sensor is under the front bumper somewhere. Maybe I disturbed it or blocked an opening. Don't think so but you never know.
Thanks for your efforts on this SM. I knew it was there somewhere. I don't think I could have disturbed this with my rewiring but I'll give it a good look to ensure it is not obstructed and getting a clear airway. If all is clear, I will talk to the dealer who is pretty good about ignoring all the mods people like to do.
redlinernyc
02-29-2016 11:06 PM
