12k maintanence.
12k maintanence.
Hi all,
I'm almost at 12k and i got a maintanenece notification on my dash. Can anyone give me a heads up on what to do and the best way to do it? Not familiar with working with my own car.
This would be the 11250 mile service assuming you're on the 3750 schedule (unless you're in Canada so that changes which service you're at).
It would be the same as the first service - oil and filter required, inspection items not critical.
i bought my eneos oil for 45 bucks, bought oil filter and gasket from infiniti dealership,
all together 60 bucks, then went to change oil myself, i HIGHLY doubt i had any problems with my hose, belt, break pad cuz its only the first maintenance... so i skipped that :P
Yes, unless you do something horribly wrong and your screwup turns out to be the cause of some problem with the car. ![Doh](https://www.myg37.com/forums/images/smilies/doh.gif)
When you have maintenance done at anywhere other than the dealership you should keep receipts and log the mileage and date of the service. When you do it yourself, keep receipts for the materials and be sure to keep a record of what you did and you will be fine.
350zrunnin12s
08-09-2015 09:55 PM
Lou@Amplified
06-04-2009 10:59 AM
