Help Whats the size and thread pitch of the end link nut for rear sway bar??? ASAP
Like the title says. I think I finally found out where the slight vibration i've been getting is coming from. I thought i'd check and tighten my sways and everything and pulled off the rear right and found the sway completly DISCONNECTED! I followed BlackBetty's DIY to the T. Torqued to the right specs and everything.
Anyways, I know it is a 14mm but what is the thread pitch and everything?
I was hoping I wasnt gonna have to do it, but I guess it's my only option. I dont have a torque wrench handy so I didnt want both sides to be out of spec. I guess I'll just take it off and go get another one and tighten then by hand. Then see if I can find a torque wrench at autozone or something tomorrow and get them back in spec.
K, i got everything all fixed. The nuts are M10x1.25 hex flange nuts. Went a head and picked up 2 new ones at ace and just replaced both the rears. Didn't have a torque wrench so I just got them as tight as I could with a breaker bar in the tight space under the car. If I have time tomorrow I'll stop by autozone and borrow one real quick to check them.
[/thread closed]
[/thread closed]
Actually, tightening them that much is a very bad idea. Overtightening fasteners is often worse than undertuightening. It can stretch or put excessive stress on the component causing it to snap. This is really bad in wheel studs (torque them to 80 ft/lbs and no more). Buy a cheapo torque wrench for $20-$30 at Auto Zone. Take them off and put them back on at the right torque.
If you're worried about the nut backing off, put some blue Loc Tite on the thread but it shouldn't be necessary.
I don't think they are that tight. My breaker bar is only about a foot long and I was working under the car with one hand. But I know what ya mean about over tightening. I'll be sure to stop by autozone in the morning and see if I can borrow the rental torque wrench and get them to the right spec.
