Help Do i have to change my OIl?
Old 03-31-2009, 04:54 AM
  #31
Seer
Seer's Avatar
IMO, if you are using full synthetic oil and changing it every 3K miles you are just wasting tons of money! Stop right now. If you use a full synthetic, which is great to do, you can safely change every 5K at a minimum. Even Infiniti only recommends every 3750. Personally, I'd recommend changing your filter and topping off after about 5K and then oil and filter after another 5K but that's just me and my personal experience with Nissan engines and synthetics.
Royal Purple or Mobil 1 it really doesn't matter as both are high quality fully synthetic oils. Any quality synthetic will work.
agreed... Blackstone labs always shows full synthetic and synthetic blend oils (i.e. mobil 1) lasting upwards of 10,000 miles, and still a lot of life left past that.
Old 04-29-2009, 12:36 AM
  #32
boss23
boss23's Avatar
dosnt the dealer do it for free ?
Old 04-29-2009, 12:53 AM
  #33
hispeed-lowdrag
hispeed-lowdrag's Avatar
the dealer will NOT replace with any kind of synthetic (you MIGHT be able to get them to if you have a friend in the service dept.) they will just change it out with regular...go to a shop or you can even go to walmart (if you trust them with your car ) and tell them you want mobil1 or whatever and have them do it. the synthetic oils are SOO much better for your engine in the long run
Old 06-23-2009, 12:21 AM
  #34
ivory37
ivory37's Avatar
Im at around 18,000 miles on an 08 coupe, 6 speed and wanted to switch to synthetic. Can anyone tell me the exact name of the synthetic oil I should buy. Infiniti wont tell me cuz they said they dont recommend synthetic. Thanks
Old 06-23-2009, 12:53 AM
  #35
RedG37SNC
RedG37SNC's Avatar
The Warrenty's documented here:http://www.infinitiwarranty.com/deal...nty-plans.aspx
MAINTENANCE RECORDS
Receipts covering the performance of regular maintenance
should be kept in the event questions
arise concerning maintenance. The receipts should
be transferred to subsequent owners.
Old 06-23-2009, 01:08 AM
  #36
RedG37SNC
RedG37SNC's Avatar
Page 9-6 in your manual documents the recommendation, basically any oil that's API certified, even has a picture of the seal to look for. Standard viscosity recommendation is SAE 5w30, so any oil that meets these standards would not void your warrenty. The wording is such that you could even use 0w30 if you're in a cold climate.
Select only engine oils that meet the American Petroleum Institute (API) certification or International Lubricant Standardization and Approval Committee (ILSAC) certification and SAE viscosity standard. These oils have the API certification mark on the front of the container.
Old 06-24-2009, 12:57 AM
  #37
fkat
fkat's Avatar
Monitoring miles and changing is straight forward but what if you don't put on much mileage? How old should the oil be before changing?
Old 06-24-2009, 01:26 PM
  #38
w0ady
w0ady's Avatar
never let it sit longer than 3 months is what i usually see.
4DRZ
10-02-2015 09:54 AM
Victory
09-28-2015 10:49 PM
tite_tite
09-25-2015 10:21 PM
cyberone28
09-23-2015 01:56 PM
sharmelan
17
09-14-2015 03:18 PM
Quick Reply: Help Do i have to change my OIl?
