Pressing the gas pedal (info)
I got the following information from the shop manual.
The accelerator pedal position sensor is installed on the upper end
of the accelerator pedal assembly. The sensor detects the accelerator
position and sends a signal to the ECM.
Accelerator pedal position sensor has two sensors. These sensors
are a kind of potentiometers which transform the accelerator pedal
position into output voltage, and emit the voltage signal to the ECM.
In addition, these sensors detect the opening and closing speed of
the accelerator pedal and feed the voltage signals to the ECM. The
ECM judges the current opening angle of the accelerator pedal from
these signals and controls the throttle control motor based on these
signals.
Idle position of the accelerator pedal is determined by the ECM
receiving the signal from the accelerator pedal position sensor. The ECM
uses this signal for the engine operation such as fuel cut.
signals.
Does this mean that pressing the gas pedal faster yields different results than easing into the throttle fully?
37
10-17-2020 11:12 AM
FlyIce
09-29-2015 04:07 AM
r0cketm0nkey
09-27-2015 01:34 PM
