Rear gear ratio???
after hearing lots of stock G35 coupes exhaust tones I thought the 37 would come down with something even better! major fail there
i'm surprised you even heard the stock exhaust.. or must've been the engine sound you were hearing she mustve been flooring it wasnt she (i'm telling you.. go propose now! lol)
you can't go wrong with FI
what? is that japanese for Fast Intentions lol
me? bias? what are you talking about shumby
I believe FujiWhatEver only came out for the G35s no one has mentioned it before on here
P.S. FI FTMFW!
P.S. FI FTMFW!
I can understand the bias you may have but you have to step back and take a look at it from my point of view. I really want to get her an exhaust but I have to be careful and choose wisely. If the exhaust is too loud and hampers her phone calls (god forbid), my modding of her car will come to a screeching halt right away. I need something with no drone.
A 3:69 is a good ratio. It tall enough your not running high rpm's on the freeway, but its low enough its good at low speeds, roll ons, and out of the hole. I personally wouldnt change it unless you plan to track or drag it, then the ratio will depend on where the motor is tuned (rpm wise). Hope that helps.
Ive been searching and cant get a definitive answer here... I am in the hunt for a VLSD pumpkin for my 370z and I have a chance at a 3.7 pumkin but it may be out of an auto, soooo than i believe the ratio would be lower than my car and at that point wouldnt work since mine is a 6m..
Its positive the AT is 3.69 ? and 6m final drive is ????
thanks in advance
thanks in advance
Grayg37s
09-27-2015 03:12 PM
