Help Fuel Gauge Questions!
#31
I have this issue now. Every time I fill up, it stops at the first 1/8 mark. No big deal, but very annoying.
So I guess some here did mention that it should be under warranty? Speaking about warranties, how long is the warranty of the vehicle?
#32
mine is doing the exactly samething. i usually stop filling up after the nozzle click to prevent from over filling. it used to be fine but now it doesnt go all the way up to where it says F.
#36
My car just started doing the same thing. Every fill up before, my gauge would always be significantly over Full and move there right after I start the car. Now, after a fill up, it moves to 3/4 full and slowly creeps up to the Full position.
Any issues with bringing this to the dealership?
Thanks
Thanks
#38
i have a similar problem, tho my gauge does go to the F after i fill gas till it clicks off. my concern is the miles left till empty. so fill up it says upper 300s an lowers as i use the gas, which is normal. but as it gets to 90 miles left/quarter tank, it jumps to 0miles left, gas light turns on, and goes from quarter to empty. its not a real big deal, but it would be nice for accurate reading, other than that the readings are jus for show.
an when i fill the tank after it says 0miles left, i only fill about 13-14gal till it clicks off.
gammamotors
44
12-31-2015 12:48 AM
