Tire Pressure COLD and Hot Weather.
Hi! All,
Can anyone help me. Tire Pressure Sensor warning light came up yesterday.
What PSI should i put for Cold Weather and Hot Weather. I know Max.PSI is
51 psi.Thx in advance.
Considering I live in FL and maybe gets to be 50 here one night a year, I'm not sure if its a good idea to raise or lower the PSI depending upon the outside temperature. However, the PSI can drop about 1 pound every 10 degrees cooler it gets. The tires should be at 35 PSI all around when the tires are cool (have not driven on them in over 4 hours). Check your tires if you just purchased your car because they are most likely around 45-50 PSI.
Remember to check your spare tire every 60 days too or before going on a long trip!
Thanks! I just drive around with over 16MPH for 15 MN. with 35 PSI all around
Warning light still show up.So..I went to put more PSI to 45PSI and run again
but nothing happended! light still show.I will see again this evenning and try on the highway.
You should keep the tire pressure at recommended specs measured with the tires cold. Over/under inflation will cause tire wear problems and affect handling.
When the warning light came on in winter on my G35, I'd air the tires up and it usually took just a few miles of driving before the warning light went out.
