Smog check failed after new battery
Old Yesterday | 08:42 PM
ExtraCrispy's Avatar
ExtraCrispy
I have a 2010 Journey. My battery had to be changed (btw is it normal for battery to last < 5years and esp since I've done much less driving due to Covid?). Got a new one installed but I didn't know that would cause a smog check to fail.
What do I need to do and how long to wait before I test again? Car has no other issues, I've read its 100 miles driving or some specific procedures to reset the codes?
I have a cheap bluetooth ODB scanner I never really used, can I use that to check the codes etc? If so please tell me specific methods/apps to use.
Old Yesterday | 09:15 PM
digital.aaron's Avatar
digital.aaron
Here, when you fail a smog check, they give you the ODBII codes. If you have a scanner, you should be able to read the codes. If you can't figure out your bluetooth one, you can borrow one from AutoZone, and possibly from other parts shops. Knowing the particular codes being thrown will help you narrow down your causes. I'm 99% sure your new battery isn't the cause.
Old Yesterday | 11:43 PM
socketz67's Avatar
socketz67
I can’t understand for the life of me how battery replacement would cause you to fail smog. I think this as a coincidence
JSolo
07-08-2021 01:57 PM
Roblom
General Tech Questions
06-09-2020 03:36 PM
Kampuchea_G
07-31-2017 06:04 AM
oliveview
07-18-2017 10:57 AM
esther
01-08-2015 08:42 AM
Quick Reply: Smog check failed after new battery
