Exhaust advice for stock G37
Old 03-14-2024 | 04:05 AM
ajtit's Avatar
ajtit
stock g37 120k miles but runs perfectly and was kept by a friends dad who kept amazing care of the car. i want it to be a little louder but nothing crazy and don’t want the trumpet **** everyone talks about with vqs? what could and exhaust mods are the best? i dont want a loud car just one with a bit more
Old 03-14-2024 | 08:13 AM
If the current cat back is solid, then keep it and replace your cats. A little bit louder, a little bit deeper, and a little added grunt.
Old 03-15-2024 | 08:51 AM
Nitro15's Avatar
Nitro15
The best mod I ever did to my first G37X was swapping in the coupe resonators. It was such a simple exhaust mod but made a world of difference. I had a shop cut out the stock resonators on my sedan & replace them with an OEM pair from a G37 coupe. Another forum member had recommended it so I went ahead & gave it a try. It was the perfect amount of sound I was looking for. If this is something you might be interested in, I'd highly recommend bringing your car to a shop you trust. There is some welding involved & if it isn't done right, it may sound raspy after a while. Keep in mind this is by no means "loud" by any stretch of the imagination. It's more of a subtle increase over the stock volume but you're able to "hear" more of the exhaust frequencies, almost identical to a stock sounding coupe. I hope this helps, good luck!
brianstucka (04-02-2024)
Old 03-17-2024 | 03:12 AM
takeapieandrun's Avatar
takeapieandrun
The setup I had which took me a long time to perfect (no drone, sounds nice but not too loud) - top speed pro 1 catback and ebay 2.5" y pipe. I also had ART pipes for added aggressiveness.
Old 03-17-2024 | 03:39 PM
socketz67's Avatar
socketz67
Smaller resonators (coupe or Vibrant makes a set that's the same size as the coupe) and an Axleback is likely the safest bet. I run this setup and believe it sounds the way the car should have stock.
If you have $2500 or so burning a hole in your pocket and want more power with an absolutely intoxicating sound, then I think the Motordyne shockwave catback owns the podium: https://motordyneengineering.com/pro...rwd-shockwave/
Stillen also has their catback on sale with an extra 15% off coupon code now: https://stillen.com/products/2009-20...-system-504377
STownSaint (04-03-2024)
Old 04-01-2024 | 12:02 PM
Sea Stories's Avatar
Sea Stories
My G is stock except for a Tanabe Medallion axle back and Vibrant resonators that I am very happy with. There is no droning on the highway, no trumpet sound, and you do not notice additional exhaust noise inside the car until you rev it out. I bought the complete setup from a member here who really did his homework.
Whatever you choose, I found it easier to unbolt the exhaust hanger brackets from the car and then transfer the rubber hangers to the new exhaust instead of pulling the rubber off the brackets. I have no rust underneath. YMMV.
Sea Stories
Old 04-02-2024 | 11:56 AM
Krzysztof47's Avatar
Krzysztof47
As for sound the Revel / Tanabe Axle back is a great piece of kit. Gives the car a nice cold start sound and good sound on throttle. No drone or rasp.
Old 04-02-2024 | 12:10 PM
RobC7's Avatar
RobC7
I agree with the Tanabe axle back. Not only does it sound great it looks the part too. I have added Nismo/IPL h-pipe and midpipe to mine for more flow and additional sound.
The following 4 users liked this post by RobC7:
Krzysztof47 (04-03-2024), Rochester (04-02-2024), Sea Stories (04-04-2024), STownSaint (04-03-2024)
Old 04-03-2024 | 11:18 PM
STownSaint's Avatar
STownSaint
Agreed with intoxicating
The Motordyne system might be too loud for what you’re looking for, but if you’re flexible on volume, I highly recommend considering it. Tony at Motordyne is the maestro to the Shockwave’s symphony
twerk
04-23-2014 10:07 AM
Bell83
Buying & Leasing
03-12-2013 01:42 AM
GGGGGWhip
Picture Share G Coupe
17
03-09-2013 10:02 PM
pkim4
02-07-2013 08:05 PM
Quick Reply: Exhaust advice for stock G37
