Is my ECU fried or something else?
Old 11-06-2023 | 08:28 PM
eliuharo's Avatar
eliuharo
I recently just replaced my spark plugs for the NGK GTR sparks and some z1 high ignition coils. After this job I took it on a test run and everything seemed fine I had more throttle response — however towards the end of the drive I experienced some weird shifting then when sitting at idle for one minute (I ran inside my house to grab something and came back), my engine “spuddered” off (according to my homie who was outside) and my fans were still running.
- turns out we had two different ground wires loose.
- we checked all the fuses (visually) and they seemed fine
- no leakage or any sort of other harnesses being lose
- When trying to start my car it goes no further than turning on all the electronics but there’s no crank, no tick when trying to start the engine.
- tried reading a code with a scanner but while the scanner turned on, it couldn’t read the car.
Im pretty sure the loose ground wires fried the ECU, every time I turn on the car everything but the engine turns on, even the fans start running but no crank.
timmywithvqs (10-25-2024)
Old 11-06-2023 | 10:40 PM
SkysG37's Avatar
SkysG37
ALL the fuses?
even the ones in the IPDM?
No power at the obd port points to a blown fuse.
hopefully it did its job and protected your ECM
Old 11-07-2023 | 12:00 AM
eliuharo's Avatar
eliuharo
Originally Posted by SkysG37
ALL the fuses?
yep, all of em. Used a fuse tester to check every single fuse and they’re all fine. OBD2 turns the scanner on but no reading.
Old 10-25-2024 | 08:34 AM
timmywithvqs's Avatar
timmywithvqs
what did your problem end up being? i am having this same issue after doing an engine swap. my new ecu’s keep on frying and then the same thing. the fans turn on but the car won’t crank. the car drove 200 miles and then this started happening
1SLOW37
08-13-2022 05:11 PM
SlowG37s
03-06-2022 10:45 AM
grailedmund
01-31-2021 09:29 PM
Bottie
01-29-2020 01:29 AM
Quick Reply: Is my ECU fried or something else?
