2010 G37 no packing light, reverse light, gear indicator light, Hazzard light
Hello Everybody,
I just got my G37 not long ago and I have a problem. After I bought the car I had some issues with some of the modules which has been fixed the car is almost complete as there's just only 2 things left to fix, the first is the throttle pedal it works but after a while it stops working and triggers a P1239 error code if I wiggle the harness or unplug and replug it works, so I have a basic idea on what is wrong with that however the one that is giving be sleepless night is the the one with the lights.
When I bought the car the hazard light was working and so was the parking light and the trafficator, but I don't know what happened but during the replacement of other modules the lights stopped working. These are the lights that do not work:
Parking Light,
Hazard Light (it flash once only on the instrument cluster just once when pressed and it doesn't show on the lights outside. if I hold it, it will continue to work but doesn't show outside other than once I release it will stop flashing),
Gear Indicator light,
Reverse Light(the reverse camera won't come on due to the lights not coming on, I have done self diagnostic and the camera works perfect),
Headlight (sometimes it works and goes off immediately)
Every other lights except from these works including interior light and dash lights and buttons light they all work... I have checked all I could check and I came up with nothing ... Any help will be appreciated... I don't know if there's a module that controls these light and if there's one please I would love someone to point me in the right directions. Thank you all in advance
Parking Light,
