Unknown Loud Squealing Passenger Side
Old 08-12-2023, 07:37 PM
zphillips62
zphillips62's Avatar
Originally Posted by mummy2
The sport brakes are easy. Can't speak on the regular calipers. I can change pads in about 10 minutes per axle using an impact wrench and a screw driver. And that includes taking the wheels on and off. Add a few extra minutes for changing rotors. The fronts are extra easy since you can turn the wheel out to get easy access to everything.
Yea its been fun learning and doing all of this, just not sure what's causing that noise. But I'm gonna keep trying and hopefully I can fix it. Any chance it might not be related to brake system? I have only assumed that because the sound stops when I press the brake. Would there be any other part that gets affected like that when I brake?
Old 08-12-2023, 09:00 PM
ILM-NC G37S
ILM-NC G37S's Avatar
Received 1,328 Likes on 1,075 Posts
I take it you just replaced the pads and did not replace or resurface the rotors? Either the pads were not properly bedded into the rotor or something is hitting the rotor (wear indicator/ dust shield/ or the "lip" the "mechanic" pointed out to you).
Did you bed the pads?
Old 08-12-2023, 09:35 PM
zphillips62
Yea so the first time I only did the pads and did not resurface or replace the rotors, and unfortunately I was unaware of the bedding process. And then after researching more, when I put in the new front rotors, I did the bedding process, but still did not replace rear rotors. So if that's the reason possibly, then I will be fixing that when my StopTech set gets here, I will definitely go bed the pads and make sure everything is greased properly. I will also make sure to check the dust shield again. Thanks for all your help! After I put the new brakes I'll update here.
Old 08-12-2023, 10:31 PM
zphillips62
Also what would be your reccomendation for the bed-in procedure?
Old 08-12-2023, 11:00 PM
mummy2
mummy2's Avatar
This is what I always do, even with blank rotors.
Old 08-21-2023, 11:42 PM
mummy2
mummy2's Avatar
Any updates?
Old 08-22-2023, 12:01 AM
zphillips62
Any updates?
Yea! So I fixed it when I just put the new rotors and pads in. After all your guys' help, I'm pretty sure its just because I didn't do much research before replacing brake pads for the first time, so I didn't really clean anything, regrease, or resurface the rotors and just popped new pads in. This past weekend I put new rotors and pads in and made sure to clean and regrease everything, and all is back to normal! Thanks guys!
Klaus_2003
12-04-2022 09:46 AM
BluSlate37x
07-22-2014 02:26 PM
VossenG37S
10-24-2011 09:12 PM
Coupe Daddy
12-06-2010 10:24 PM
Goonz
04-03-2010 10:16 PM
Quick Reply: Unknown Loud Squealing Passenger Side
