G37 wont start and Dash wont work
Hi i bough a aftermarket radio and tried installing it by myself. when i took out the radio i started the car to move from P to N to remove the middle dash and then i removed stock radio and then put it back now i cant start my car and my speedometer wont turn on and the car wont shift or turn on, Please tell me what issues you think went wrong thank you so much and where do you think i can get it fixed.
Did you unplug the amp: the plastic white box attached to the OEM radio/ headunit?
If you, did you plug it back in. And, notice the yellow tape on the connectors, make sure they are plugged into the amp. It is very easy to mix up the connectors in the center stack area and plug them into the wrong location.
MakaiB74
08-19-2022 10:56 PM
