Custom exhaust
Custom exhaust
Had some money saved for a CBE but then ran into some real life problems and had to put my exhaust on the back burner. So here we are and now I have leaks from my flex pipes and one of my tips rusted off, the other is not far behind. So it's time to do something about it. Right now my system is stock other than a muffler delete with the custom tips.
I'm looking at, ISR Y-pipe, probably a custom mid pipe with 12" vibrant resonators??? And then HKS Hi-power mufflers. Thoughts? Suggestions?
The problem I foresee is the 3" exit on the Y-pipe to the 2.5" inlet on the mid pipe. But if I have that mid pipe custom made with a larger inlet, I should be fine ....right?
Should be fine. I would go ahead and replace the whole 2.5 section with 3 not just the inlet.
I'm buying a Meisterschaft Y-pipe and Tanabe coupe mid-pipe from @pauliewalnutzz then I'm going to have the exhaust shop modify the mid-pipe for my sedan. Probably throw some HKS Hi-power mufflers on the back. I guess we'll see how it goes. If I can I'll take some pictures of the process and make a post on how it sounds.
I looked this up. I don't see anything that's still kept up with here in 2023 other than a list on Amazon. That and some guy on YouTube that makes videos? I did not check into the YouTube account to see what it was about. So I have no idea what I'm looking for here. I'm assuming maybe this guy makes custom exhaust upon request or something?
