Brake/Traction lights upon acceleration
Hello all, a few weeks ago I started noticing the brake light on the gauge cluster coming on upon heavy acceleration. Now it's turning on pretty much anytime I'm accelerating at 1/2 throttle or more. It's also tripping my traction control light on occasion.
My best guess would be a wheel speed sensor? But I wanted to see if anyone else has had this kind of issue. Not sure what to make of it.
Shawn Aucutt (01-10-2023)
Moderador
abrecos (11-18-2022)
It is definitely from brake fluid pitching forward under braking, any time you see the lights flicker it's time to check your fluid - or realistically, your front pads since it likely means they are worn down.
Good luck!
Rick
bread
03-03-2023 04:43 PM
m3clubracer
11-15-2018 09:23 AM
