G37xS AWD with Coupe Wheels Help
I just got these 19 inch coupe wheels running staggered setup on my g37 AWD. 245/40/19 front 285/35/19 rear. Is there anything I need to worry about suspension wise? I’ve had bad history with wheels damaging my suspension 😭
You should be good to go with that setup. Your 285/35 are about as wide as I would go on the 9 inch wide rear rims. You could throw on some 10 or 15 mm spacers on the front just to bring the fronts out a little and more flush with the fenders, but that is just my opinion.
