Where are working FSMs?
None of the links work for the FSM's anymore? Where can I get them? Does anyone have copies they can host???? Been around for a minute here guys help me out boys.
Worked for me this morning when I downloaded some for the Murano. Granted, NicoClub is very slow- almost to the point it seems "hacked(?)" as it drives my Little Snitch/ firewall crazy blocking all sorts of crap, but it does work.
What particular section do you need and for what car?
Need it for the G37 Sedan 2010 need to replace the serpentine belt and idler pully the bearings are destroyed. Doing my daily 70 mile commute home and on the way home heard a pop and noticed PS and AC gone. Was hoping belt snapped but nope found this pulley sitting in the bottom cover shroud under the engine.
Spun right off! Hardware and engine threads seem to be fine. Already purchased a replacement from Z1Motorsports with overnight FEDEX right under $100, and new belt $55 from O'Reilys. Sure this whole thing would have cost be $600+ Anywhere else to get done.
Here you go. Just downloaded. My Mac is cursing right now... NicoClub site has SERIOUS issues...
Some have had issues with those bolts not being torqued properly and working loose as the bearing ages. Luckily you were able to identify and repair the issue on your own.
Anyhow, see page 26.
Well here are the part numbers if you want to replace just the bearings.
https://www.myg37.com/forums/d-i-y-i...-bearings.html
I ordered them and they all seem to be right. Didn't finish installing yet.
