Cruise control not working
My cruise control buttons dont work. When I press on them nothing happens not even a light on the dash. My other steering wheel buttons and horn do work though.
I replaced my clockspring and steering wheel and still nothing.
Check your dash to see if your ABS light is illuminated with the engine running. If so, the cruise control simply won't turn on until you rectify the issue with your ABS system. The same will happen if your traction control (VDC) is turned off or doesn't work.
Next, check your fuses. There are three fuses that are related to cruise control that I know of, they are fuses № 3 and 7 in the passenger compartment fuse box, and fuse № 45 in engine compartment fuse box #1.
- View this page for reference on where to find the fuses I mentioned: https://fuse-box.info/infiniti/infin...ses-and-relays
If the fuses I mentioned are good, the next thing I would check is the cruise control actuator. Either have a professional examine it for you or dust off your digital multimeter and do a continuity test on the electrical connections of the actuator.
If your cruise control warning light illuminates, check the cruise control module. Or check to see if depressing your brake and/or clutch pedal makes the respective pedal come into contact with the cruise control deactivation button (or whatever it's called, I'm not a mechanic). If pressing down those pedals doesn't lead to the button being pressed down, the cruise control light will flash on your dash. See this $hitty video for more details on the subject:
That's as far as I can help you with. If none of that helps, then I apologize ahead of time.
If your cruise control warning light illuminates, check the cruise control module. Or check to see if depressing your brake and/or clutch pedal makes the respective pedal come into contact with the cruise control deactivation button (or whatever it's called, I'm not a mechanic). If pressing down those pedals doesn't lead to the button being pressed down, the cruise control light will flash on your dash. See this $hitty video for more details on the subject: https://www.youtube.com/watch?v=tTfNRmXL5GU
Dieseldoug22
07-02-2009 02:32 PM
