G37 is leaking coolant once again. Any thoughts?
Good evening everyone. I am back once again because my 2013 G37 is leaking coolant again. I noticed it a few hours ago when I started the car. I heard a swishing sound in the engine, and while backing up I saw a puddle. I quickly parked the car, and upon further inspection I saw a puddle of coolant. The hoses and water pump was replaced barely a year ago in an Infiniti dealership, and I drove about 5000 miles after the repair. I did notice that the coolant is leaking in the passenger side and I can't really see where it is leaking from in the engine. Thank you all once again and hello to everyone who participated in my previous threads.
Heater hose connector? Passenger side rear of engine. VERY common failure for these cars.
DIY Heater Hose Connector
Easy fix but a pain to get adequate access.
abrecos (01-30-2022)
https://www.myg37.com/forums/engine-...upler-fix.html
Yup like what others have said, most likely it's the heater hose connector. The plastic connector becomes a ticking bomb once your car reaches certain miles. Mine started leaking around 75 to 80K miles. It's best to get it replaced around 60K with a metal one, so you won't have to worry about it in the future.
Coolant leak
It's very high probability that is heater core coupling,like guys mentioned broken and is located on passenger side of the firewall behind the engine. You don't need to involve the dealer in this unless you want to throw some serious money. Just get yourself hose spring clamps removal tool
OTC 4525 Drake Off Road Cable-Type Flexible Hose Clamp Pliers it's available on Amazon.com and get 3/4 stainless or brass barb coupler in any hardware store it's around 5-6 dollars, pull the clamps and disconnect the hoses from each side of coupler use needle nose players if coupler broken in the half then install your new coupler put the clamps on and call a day.
I took the car in this morning and the dealer did tell me a bunch of hoses deteriorated and the main cause of the leak. Had them replace all the hoses, and I am hoping this solution will last me a good while. It does make sense because my car is already at 90k miles and is daily driven in all conditions. Thank you all once again for helping me out! Drive safe!
It is a shame Nissan never updated this part to a metal piece...
A little clarification may be in order...
I agree with ILM-NC G37S. When there's coolant leaks on these cars, it's usually that cheap plastic connector, or the stock tension clamps getting weak. Hoses are usually not the problem.
My mechanic called me today and told me they had to keep the car overnight because one of the hoses did not fit right. I also called him before hand to follow up on the car and I told him to use metal for all couplings and the best materials for whatever will be replaced. He told me he would do that and would have the bill tomorrow. Hopefully this will make the car more reliable in the long run lol.
I got the car back this afternoon and it is running like top so far. I was a bit surprised though because I had a pretty hefty bill. Total came out to about $600. The service advisor and the paperwork says that they replaced radiator hoses, heater hoses, clamps, and a few other components that I don't remember. I am a bit skeptical because my car's radiator hoses was changed 10k miles ago. I am no expert, but I am sure the hoses would last longer than that. I am hoping the car will be all good now for quite a while. I already spent a few grand on repairs and maintenance.
Birdie (02-02-2022)
tite_tite
69
08-26-2024 12:37 PM
